Leopar: an Interaction Grammar Parser - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2013
Guy Perrier
  • Fonction : Auteur
  • PersonId : 8101
  • IdHAL : guy-perrier
Bruno Guillaume
Leopar {http://leopar.loria.fr) is a parser for natural languages which is based on the formalism of Interaction Grammars (IG). The parsing principle (called "electrostatic parsing") consists in neutralizing opposite polarities: a positive polarity corresponds to an available linguistic feature and a negative one to an expected feature. The structures used in IG are underspecified syntactic trees decorated with polarities and called Polarized Tree Descriptions.
demo.pdf (55.26 Ko) Télécharger le fichier
hal-00920728 , version 1 (19-12-2013)
  • HAL Id : hal-00920728 , version 1
Guy Perrier, Bruno Guillaume. Leopar: an Interaction Grammar Parser. Denys Duchier and Yannick Parmentier. ESSLLI 2013 - Workshop on High-level Methodologies for Grammar Engineering, Aug 2013, Düsseldorf, Germany. pp.121-122, 2013. ⟨hal-00920728⟩
215 Consultations
107 Téléchargements
