The vectorial λ-calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 2017
We describe a type system for the linear-algebraic λ-calculus. The type system accounts for the linear-algebraic aspects of this extension of λ-calculus: it is able to statically describe the linear combinations of terms that will be obtained when reducing the programs. This gives rise to an original type theory where types, in the same way as terms, can be superposed into linear combinations. We prove that the resulting typed λ-calculus is strongly normalising and features weak subject reduction. Finally, we show how to naturally encode matrices and vectors in this typed calculus.
1308.1138.pdf (503.26 Ko) Télécharger le fichier
hal-01785464 , version 1 (07-05-2018)
Pablo Arrighi, Alejandro Díaz-Caro, Benoît Valiron. The vectorial λ-calculus. Information and Computation, 2017, 254 (1), pp.105--139. ⟨10.1016/j.ic.2017.04.001⟩. ⟨hal-01785464⟩
363 Consultations
54 Téléchargements
