Improved and Generalized Upper Bounds on the Complexity of Policy Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Scherrer
Given a Markov Decision Process (MDP) with $n$ states and $m$ actions per state, we study the number of iterations needed by Policy Iteration (PI) algorithms to converge to the optimal $\gamma$-discounted optimal policy. We consider two variations of PI: Howard's PI that changes the actions in all states with a positive advantage, and Simplex-PI that only changes the action in the state with maximal advantage. We show that Howard's PI terminates after at most $ O \left( \frac{ n m}{1-\gamma} \log \left( \frac{1}{1-\gamma} \right)\right) $ iterations, improving by a factor $O(\log n)$ a result by Hansen et al. (2013), while Simplex-PI terminates after at most $ O \left( \frac{n^2 m}{1-\gamma} \log \left( \frac{1}{1-\gamma} \right)\right) $ iterations, improving by a factor $O(\log n)$ a result by Ye (2011). Under some structural assumptions of the MDP, we then consider bounds that are independent of the discount factor~$\gamma$: given a measure of the maximal transient time $\tau_t$ and the maximal time $\tau_r$ to revisit states in recurrent classes under all policies, we show that Simplex-PI terminates after at most $ \tilde O \left( n^3 m^2 \tau_t \tau_r \right) $ iterations. This generalizes a recent result for deterministic MDPs by Post & Ye (2012), in which $\tau_t \le n$ and $\tau_r \le n$. We explain why similar results seem hard to derive for Howard's PI. Finally, under the additional (restrictive) assumption that the state space is partitioned in two sets, respectively states that are transient and recurrent for all policies, we show that Simplex-PI and Howard's PI terminate after at most $ \tilde O(nm (\tau_t+\tau_r))$ iterations.
nips2013.pdf (272.03 Ko) Télécharger le fichier
hal-00921261 , version 1 (20-12-2013)
  • HAL Id : hal-00921261 , version 1
Bruno Scherrer. Improved and Generalized Upper Bounds on the Complexity of Policy Iteration. Neural Information Processing Systems (NIPS) 2013, Dec 2013, South Lake Tahoe, United States. ⟨hal-00921261⟩
244 Consultations
309 Téléchargements
