Duty-Cycle Power Manager for Thermal-Powered Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Exploiting energy from the environment to extend the system lifetime of Wireless Sensor Network (WSN), especially thermal energy, is considered as a promising approach. When considering self-powered systems, the Power Manager (PM) plays an important role in energy harvesting WSNs. Instead of minimizing the consumed energy as in the case of battery-powered systems, it causes the harvesting node to converge to Energy Neutral Operation (ENO) in order to achieve a theoretically infinite lifetime. In this paper, a low complexity PM for a thermal-powered WSN is presented. Our PM adapts the duty cycle of the node according to the estimation of harvested energy and the consumed energy provided by a simple energy monitor for a super capacitor based WSN to achieve the ENO. Experiments are performed on a real WSN platform where harvested energy is extracted from the wasted heat of a PC adapter by two thermoelectric generators.
Fichier non déposé
hal-00921315 , version 1 (20-12-2013)
hal-00921315 , version 2 (11-07-2016)
Trong Nhan Le, Alain Pegatoquet, Olivier Sentieys, Olivier Berder, Cécile Belleudy. Duty-Cycle Power Manager for Thermal-Powered Wireless Sensor Networks. 2013 IEEE 24th Annual International Symposium on Personal, Indoor, and Mobile Radio Communications (PIMRC), Sep 2013, Londres, United Kingdom. pp.1645-1649, ⟨10.1109/PIMRC.2013.6666406⟩. ⟨hal-00921315v2⟩
527 Consultations
0 Téléchargements
