Multi-Source Power Manager for Super-Capacitor based Energy Harvesting Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a multi-source power manager (PM) is applied using different types of energy harvesting WSN. Specifically, this PM is embedded in both thermal and solar-powered WSN in order to adapt the consumed energy of the node by changing its wake-up period according to the harvested energy. Experimental results performed on real WSN platforms show that our PM is able to make harvesting nodes converge to Energy Neutral Operation (ENO) with a theoretically infinite system lifetime.
Fichier non déposé
hal-00921320 , version 1 (20-12-2013)
Trong-Nhan Le, Alain Pegatoquet, Olivier Berder, Olivier Sentieys. Multi-Source Power Manager for Super-Capacitor based Energy Harvesting Wireless Sensor Networks. 1st International Workshop on Energy Neutral Sensing Systems (ENSSys) organized in conjunction with 11th ACM SenSys Conference, Nov 2013, Rome, Italy. Paper 19, ⟨10.1145/2534208.2534227⟩. ⟨hal-00921320⟩
406 Consultations
0 Téléchargements
