Symbolic Mapping and Allocation for the Cholesky Factorization on NUMA machines: Results and Optimizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of High Performance Computing Applications Année : 2013
We discuss some performance issues of the tiled Cholesky factorization on non-uniform memory access-time (NUMA) shared memory machines. We show how to optimize thread and data placement in order to achieve performance gains up to 50% compared to state-of- the-art libraries such as PLASMA or MKL.
jeannot.pdf (274.07 Ko) Télécharger le fichier
hal-00921611 , version 1 (20-12-2013)
  • HAL Id : hal-00921611 , version 1
Emmanuel Jeannot. Symbolic Mapping and Allocation for the Cholesky Factorization on NUMA machines: Results and Optimizations. International Journal of High Performance Computing Applications, 2013, 27 (3), pp.283--290. ⟨hal-00921611⟩
142 Consultations
136 Téléchargements
