An Overview of Process Mapping Techniques and Algorithms in High-Performance Computing
Due to the advent of modern hardware architectures of high-performance comput- ers, the way the parallel applications are laid out is of paramount importance for performance. This chapter surveys several techniques and algorithms that efficiently address this issue: the mapping of the application's virtual topology (for instance its communication pattern) onto the physical topology. Using such strategy enables to improve the application overall execution time significantly. The chapter concludes by listing a series of open issues and problems.
