Integrating textual knowledge and formal knowledge for improving traceability
Knowledge engineering often concerns the translation of informal knowledge into a formal representation. This translation process requires support for itself and for its We pretend that inserting a terminological structure between informal textual documents and their formalization serves both of these goals. Modern terminology extraction tools support the process where the terms are a first sketch of formalized concepts. Moreover, the terms can be used for linking the concepts and the pieces of texts. This is exemplified through the presentation of an implemented system.
Intelligence artificielle [cs.AI]
