FCAIR 2012 Formal Concept Analysis Meets Information Retrieval Workshop co-located with the 35th European Conference on Information Retrieval (ECIR 2013) March 24, 2013, Moscow, Russia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2013
Claudio Carpineto
  • Fonction : Directeur scientifique
  • PersonId : 950284
Sergei O. Kuznetsov
  • PersonId : 833204
Amedeo Napoli
Formal Concept Analysis (FCA) is a mathematically well-founded theory aimed at data analysis and classifiation. The area came into being in the early 1980s and has since then spawned over 10000 scientific publications and a variety of practically deployed tools. FCA allows one to build from a data table with objects in rows and attributes in columns a taxonomic data structure called concept lattice, which can be used for many purposes, especially for Knowledge Discovery and Information Retrieval. The Formal Concept Analysis Meets Information Retrieval (FCAIR) workshop collocated with the 35th European Conference on Information Retrieval (ECIR 2013) was intended, on the one hand, to attract researchers from FCA community to a broad discussion of FCA-based research on information retrieval, and, on the other hand, to promote ideas, models, and methods of FCA in the community of Information Retrieval.
FCAIR-2013-proceedings.pdf (3.04 Mo) Télécharger le fichier
hal-00922617 , version 1 (28-12-2013)
  • HAL Id : hal-00922617 , version 1
Claudio Carpineto, Sergei O. Kuznetsov, Amedeo Napoli (Dir.). FCAIR 2012 Formal Concept Analysis Meets Information Retrieval Workshop co-located with the 35th European Conference on Information Retrieval (ECIR 2013) March 24, 2013, Moscow, Russia. Claudio Carpineto and Sergei O. Kuznetsov and Amedeo Napoli. CEUR Proceedings, 977, pp.157, 2013. ⟨hal-00922617⟩
200 Consultations
880 Téléchargements
