On Optimal Packet Routing in Deterministic DTNs
In this paper, we investigate the problem of determining the routing that minimizes the maximum/average delivery time or the maximum/average delivery delay for a set of packets in a deterministic Delay Tolerant Network, i.e. in a network for which all the nodes' transmission opportunities are known in advance. While the general problem with multiple sources and multiple destinations is NP-hard, we present a polynomial time algorithm that can efficiently compute the optimal routing in the case of a single destination or of a single packet that needs to be routed to multiple destinations.
