An operator Approach to Tangent Vector Field Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2013
In this paper, we introduce a novel coordinate-free method for manipulating and analyzing vector fields on discrete surfaces. Unlike the commonly used representations of a vector field as an assignment of vectors to the faces of the mesh, or as real values on edges, we argue that vector fields can also be naturally viewed as operators whose domain and range are functions defined on the mesh. Although this point of view is common in differential geometry it has so far not been adopted in geometry processing applications. We recall the theoretical properties of vector fields represented as operators, and show that composition of vector fields with other functional operators is natural in this setup. This leads to the characterization of vector field properties through commutativity with other operators such as the Laplace-Beltrami and symmetry operators, as well as to a straight-forward definition of differential properties such as the Lie derivative. Finally, we demonstrate a range of applications, such as Killing vector field design, symmetric vector field estimation and joint design on multiple surfaces.
hal-00923607 , version 1 (03-01-2014)
Maks Ovsjanikov, Mirela Ben Chen, Omri Azencot, Frédéric Chazal. An operator Approach to Tangent Vector Field Processing. Computer Graphics Forum, 2013, Proc. Eurographics Symposium on Geometry Processing 2013, 32 (5), pp.73-82. ⟨10.1111/cgf.12174⟩. ⟨hal-00923607⟩
318 Consultations
0 Téléchargements
