A New Algorithm to Compute Inverse Dynamic of a Class of Nonlinear Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper supplies a new algorithm to compute the internal dynamics (or inversion dynamics) of affine MIMO control nonlinear systems. This algorithm con- sider both cases regular or singular characteristic ma- trix. Furthermore, it provides an extension to a class of nonlinear descriptor systems.
CDC_DB_JPB_MD_V4.pdf (109.22 Ko) Télécharger le fichier
hal-00923663 , version 1 (03-01-2014)
  • HAL Id : hal-00923663 , version 1
Driss Boutat, Jean-Pierre Barbot, Mohamed Darouach. A New Algorithm to Compute Inverse Dynamic of a Class of Nonlinear Systems. 52nd IEEE Conference on Decision and Control, Dec 2013, Florence, Italy. ⟨hal-00923663⟩
255 Consultations
361 Téléchargements
