A Framework for Interacting Smart Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arnab Sinha
  • Fonction : Auteur
  • PersonId : 950504
Paul Couderc
  • Fonction : Auteur
  • PersonId : 833468
In this paper, we propose a framework enabling physical objects used everyday to participate in smart interactions. These objects are RFID tagged containing self description of their properties. The paper describes how smart context aware services can be supported directly by a collection of smart objects. One of the main advantage of our approach is the smart objects being piggybacked with necessary information, optimized enough to make inferences locally, without dependence on external system support.
ruSmart2013.pdf (3.08 Mo) Télécharger le fichier
hal-00924451 , version 1 (06-01-2014)
Arnab Sinha, Paul Couderc. A Framework for Interacting Smart Objects. 6th Conference, ruSMART 2013, Aug 2013, St. Petersburg, Russia. pp.40-45, ⟨10.1007/978-3-642-40316-3_7⟩. ⟨hal-00924451⟩
456 Consultations
289 Téléchargements
