Riemannian metrics on 2D manifolds related to the Euler-Poinsot rigid body problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Euler-Poinsot rigid body problem is a well known model of left-invariant metrics on SO(3). In the present paper we discuss the properties of two related reduced 2D models: the sub-Riemanian metric of a system of three coupled spins and the Riemannian metric associated to the Euler- Poinsot problem via the Serret-Andoyer reduction. We explicitly construct Jacobi fields and explain the structure of conjugate loci in the Riemannian case and give the first numerical results for the spin dynamics case.
bonnard_17149.pdf (1.67 Mo) Télécharger le fichier
hal-00925078 , version 1 (07-01-2014)
hal-00925078 , version 2 (23-02-2017)
  • HAL Id : hal-00925078 , version 2
  • OATAO : 17149
Bernard Bonnard, Olivier Cots, Nataliya Shcherbakova. Riemannian metrics on 2D manifolds related to the Euler-Poinsot rigid body problem. 52nd IEEE Conference on Decision and Control (CDC 2013), Dec 2013, Firenze, Italy. pp. 1804-1809. ⟨hal-00925078v2⟩
663 Consultations
393 Téléchargements
