Revisiting the double checkpointing algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fast checkpointing algorithms require distributed access to stable storage. This paper revisits the approach base upon double checkpointing, and compares the blocking algorithm of Zheng, Shi and Kalé, with the non-blocking algorithm of Ni, Meneses and Kalé in terms of both performance and risk. We also extend the model that they have proposed to assess the impact of the overhead associated to non-blocking communications. We then provide a new peer-to-peer checkpointing algorithm, called the triple checkpointing algorithm, that can work at constant memory, and achieves both higher efficiency and better risk handling than the double checkpointing algorithm. We provide performance and risk models for all the evaluated protocols, and compare them through comprehensive simulations.
Voir le résumé en anglais.
buddy.pdf (521.26 Ko) Télécharger le fichier
hal-00925168 , version 1 (07-01-2014)
  • HAL Id : hal-00925168 , version 1
Jack Dongarra, Thomas Herault, Yves Robert. Revisiting the double checkpointing algorithm. APDCM 2013, IEEE, 2013, Boston, United States. ⟨hal-00925168⟩
174 Consultations
268 Téléchargements
