Identification of artery wall stiffness: in vitro validation and in vivo results of a data assimilation procedure applied to a 3D fluid-structure interaction model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biomechanics Année : 2014
We consider the problem of estimating the stiffness of an artery wall using a data assimilation method applied to a 3D fluid-structure interaction (FSI) model. Recalling previous works, we briefly present the FSI model, the data assimilation procedure and the segmentation algorithm. We present then two examples of the procedure using real data. First, we estimate the stiffness distribution of a silicon rubber tube from image data. Second, we present the estimation of aortic wall stiffness from real clinical data.
inria-usfd-kcl_stiffestim_2014.pdf (5.32 Mo) Télécharger le fichier
hal-00925902 , version 1 (08-01-2014)
hal-00925902 , version 2 (09-01-2014)
Cristobal Bertoglio, David Barber, Nicholas Gaddum, Israel Valverde, Marcel Rutten, et al.. Identification of artery wall stiffness: in vitro validation and in vivo results of a data assimilation procedure applied to a 3D fluid-structure interaction model. Journal of Biomechanics, 2014, 47 (5), pp.1027-1034. ⟨10.1016/j.jbiomech.2013.12.029⟩. ⟨hal-00925902v2⟩
1046 Consultations
774 Téléchargements
