A simple Bridging Model for High-Performance Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
This report introduces the Scatter-Gather parallel-programming and parallel execution model in the form of a simple imperative language named SGL. Its design is based on past experience with Bulk-synchronous parallel (BSP) programming and BSP language design. SGL's novel features are motivated by the last decade's move towards multi-level and heterogeneous parallel architectures involving multi-core processors, graphics accelerators and hierarchical routing networks in the largest multiprocessing systems. The design of SGL is coherent with Valiant's Multi-BSP while off ering a programming interface that is even simpler than the primitives of Bulk-Synchronous parallel ML (BSML). SGL appears to cover a large subset of all BSP algorithms while avoiding complex message-passing programming. It allows automatic load balancing and like all BSP-inspired systems, predictable, portable and scalable performance.
TR-LACL-2010-12.pdf (489.24 Ko) Télécharger le fichier
hal-00926383 , version 1 (09-01-2014)
  • HAL Id : hal-00926383 , version 1
Chong Li, Gaétan Hains. A simple Bridging Model for High-Performance Computing. [Technical Report] TR-LACL-2010-12, 2010, pp.25. ⟨hal-00926383⟩
109 Consultations
415 Téléchargements
