Bounded-Curvature Shortest Paths through a Sequence of Points using Convex Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Computing Année : 2013
We consider the problem of computing shortest paths having curvature at most one almost everywhere and visiting a sequence of $n$ points in the plane in a given order. This problem is a sub-problem of the Dubins Traveling Salesman Problem and also arises naturally in path planning for point car-like robots in the presence of polygonal obstacles. We show that when consecutive waypoints are distance at least four apart, this question reduces to a family of convex optimization problems over polyhedra in $\mathbb{R}^n$.
viapoints_final.pdf (330.92 Ko) Télécharger le fichier
2013 Bounded-Curvature Shortest Paths.png (48.39 Ko) Télécharger le fichier
Format : Figure, Image
hal-00927100 , version 1 (10-01-2014)
Xavier Goaoc, Hyo-Sil Kim, Sylvain Lazard. Bounded-Curvature Shortest Paths through a Sequence of Points using Convex Optimization. SIAM Journal on Computing, 2013, 42 (2), pp.662-684. ⟨10.1137/100816079⟩. ⟨hal-00927100⟩
215 Consultations
648 Téléchargements
