À Table! Improving Temporal Navigation in Soccer Ranking Tables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article introduces A Table!, an enhanced soccer ranking table providing temporal navigation by combining two novel interaction techniques. Ranking tables order soccer teams represented as rows, according to values of columns containing attributes e.g., accumulated points, or number of scored goals. Because they represent a snapshot of a championship at a time t, tables are regularly updated with new results. Such updates usually change the rows order, which makes the tracking of a specified team over time difficult. We observed that the tables available on the web do not support tracking such changes very well, are generally hard to read, and lack interactions. This contrasts with the extensive use of comments on temporal trends found in soccer analysts articles. To better support such analyzes, the two interactive techniques presented allow exploration of time, and are designed to preserve users' flow: DRAG-CELL is based on direct manipulation of values to browse ranks; VIZ-RANK uses a transient line chart of team ranks to visually explore a championship. An on-line evaluation with 143 participants shows that each technique efficiently supports a set of important temporal tasks not supported by current ranking tables. This paves the way for introducing efficient advanced visual exploration techniques to millions of soccer enthusiasts who use tables everyday.
atable.pdf (946.99 Ko) Télécharger le fichier
Format : Figure, Image
hal-00929844 , version 1 (14-01-2014)
Charles Perin, Romain Vuillemot, Jean-Daniel Fekete. À Table! Improving Temporal Navigation in Soccer Ranking Tables. CHI 2014 - Proceedings of the 2014 Annual Conference on Human Factors in Computing Systems, Apr 2014, Toronto, Canada. pp.887-896, ⟨10.1145/2556288.2557379⟩. ⟨hal-00929844⟩
499 Consultations
1113 Téléchargements
