Delta: Scalable Data Dissemination under Capacity Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the VLDB Endowment (PVLDB) Année : 2013
In content-based publish-subscribe (pub/sub) systems, users express their interests as queries over a stream of publications. Scaling up content-based pub/sub to very large numbers of subscriptions is challenging: users are interested in low latency, that is, getting subscription results fast, while the pub/sub system provider is mostly interested in scaling, i.e. being able to serve large numbers of subscribers, with low computational resources utilization. We present a novel approach for scalable content-based pub/sub in the presence of constraints on the available CPU and network resources, implemented within our pub/sub system Delta. We achieve scalability by off-loading some subscriptions from the pub/sub server, and leveraging view-based query rewriting to feed these subscriptions from the data accumulated in others. Our main contribution is a novel algorithm for organizing views in a multi-level dissemination network, exploiting view-based rewriting and powerful linear programming capabilities to scale to many views, respect capacity constraints, and minimize latency. The efficiency and effectiveness of our algorithm are confirmed through extensive experiments and a large deployment in a WAN.
paper.pdf (249.11 Ko) Télécharger le fichier
hal-00930107 , version 1 (14-01-2014)
  • HAL Id : hal-00930107 , version 1
Konstantinos Karanasos, Asterios Katsifodimos, Ioana Manolescu. Delta: Scalable Data Dissemination under Capacity Constraints. Proceedings of the VLDB Endowment (PVLDB), 2013, 7 (4), pp.217-228. ⟨hal-00930107⟩
227 Consultations
166 Téléchargements
