Potentialities of Usrp-Based Software Defined Radar Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Progress In Electromagnetics Research B Année : 2013
Sandra Costanzo
  • Fonction : Auteur
Francesco Spadafora
  • Fonction : Auteur
Giuseppe Di Massa
  • Fonction : Auteur
Antonio Borgia
  • Fonction : Auteur
Antonio Costanzo
  • Fonction : Auteur
Ginaluca Aloi
  • Fonction : Auteur
Pasquale Pace
  • Fonction : Auteur
  • PersonId : 904279
Valeria Loscrì
  • Fonction : Auteur
  • PersonId : 1084587
Hugo Oswaldo Moreno
  • Fonction : Auteur
Software Defined Radar is the latest trend in radar development. To handle enhanced radar signal processing techniques, advanced radars need to be able of generating various types of waveforms, such as frequency modulated or phase coded, and to perform multiple functions. The adoption of a Software Defined Radio system makes easier all these abilities. In this work, the implementation of a Software Defined Radar system for target tracking using the Universal Software Radio Peripheral platform is discussed. For the first time, an experimental characterization in terms of radar application is performed on the latest Universal Software Radio Peripheral NI2920, demonstrating a strongly improved target resolution with respect to the first generation platform.
Informatique
PIER-Costanzo-1.pdf (1.17 Mo) Télécharger le fichier
hal-00931209 , version 1 (15-01-2014)
Sandra Costanzo, Francesco Spadafora, Giuseppe Di Massa, Antonio Borgia, Antonio Costanzo, et al.. Potentialities of Usrp-Based Software Defined Radar Systems. Progress In Electromagnetics Research B, 2013, 53, ⟨10.2528/PIERB13052904⟩. ⟨hal-00931209⟩
Collections
INRIA INRIA2
870 Consultations
2847 Téléchargements
