Quantum LDPC codes with positive rate and minimum distance proportional to the square root of the blocklength - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2014
The current best asymptotic lower bound on the minimum distance of quantum LDPC codes with fixed non-zero rate is logarithmic in the blocklength. We propose a construction of quantum LDPC codes with fixed non-zero rate and prove that the minimum distance grows proportionally to the square root of the blocklength.
IT_QLDPC_final.pdf (344.03 Ko) Télécharger le fichier
hal-00931764 , version 1 (15-01-2014)
Jean-Pierre Tillich, Gilles Zémor. Quantum LDPC codes with positive rate and minimum distance proportional to the square root of the blocklength. IEEE Transactions on Information Theory, 2014, 60 (2), pp.1193-1202. ⟨10.1109/TIT.2013.2292061⟩. ⟨hal-00931764⟩
291 Consultations
527 Téléchargements
