Polynomial Time Attack on Wild McEliece Over Quadratic Extensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a polynomial time structural attack against the McEliece system based on Wild Goppa codes from a quadratic finite field extension. This attack uses the fact that such codes can be distinguished from random codes to compute some filtration of nested subcodes which will reveal their secret algebraic description.
hal-00931774 , version 1 (15-01-2014)
Alain Couvreur, Ayoub Otmani, Jean-Pierre Tillich. Polynomial Time Attack on Wild McEliece Over Quadratic Extensions. Advances in Cryptology - Eurocrypt 2014, May 2014, Copenhagen, Denmark. pp.17-39, ⟨10.1007/978-3-642-55220-5_2⟩. ⟨hal-00931774⟩
437 Consultations
0 Téléchargements
