Advanced Promethee-based Scheduler Enriched with User-Oriented Methods
Efficiently scheduling tasks in hybrid Distributed Computing Infrastructures (DCI) is a challenging pursue because the scheduler must deal with a set of parameters that simultaneously characterize the tasks and the hosts originating from different types of infrastructure.
In this paper we propose a scheduling method for hybrid DCIs, based on advanced multi-criteria decision methods. The scheduling decisions are made using pairwise comparisons of the tasks for a set of criteria like expected completion time and price charged for computation. The results are obtained with an XtremWeb-like pull-based scheduler simulator using real failure traces from [1] for a combination of three types of infrastructure. We also show how such a scheduler should be configured to enhance user satisfaction regardless their profiles, while maintaining good values for makespan and cost.
We validate our approach with a statistical analysis on empirical data and show that our proposed scheduling method improves performance by 12-17% compared to other scheduling methods. Experimenting on large time-series and using realistic scheduling scenarios lead us to conclude about time consistency results of the method.
