Inference of polynomial invariants for imperative programs: a farewell to Gröbner bases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2014
The article presents a static analysis for computing polynomial invariants for imperative programs. The analysis is derived from an abstract interpretation of a backwards semantics, and computes pre-conditions for equalities of the form g = 0 to hold at the end of execution. A distinguishing feature of the technique is that it computes polynomial loop invariants without resorting to Gröbner base computations. The analysis uses remainder computations over parameterized polynomials in order to handle conditionals and loops efficiently. The algorithm can analyse and find a large majority of loop invariants reported pre- viously in the literature, and executes significantly faster than implementations using Gröbner bases.
hal-00932351 , version 1 (16-01-2014)
David Cachera, Thomas Jensen, Arnaud Jobin, Florent Kirchner. Inference of polynomial invariants for imperative programs: a farewell to Gröbner bases. Science of Computer Programming, 2014, 93, pp.21. ⟨10.1016/j.scico.2014.02.028⟩. ⟨hal-00932351⟩
283 Consultations
0 Téléchargements
