Yield Improvement by the Redundancy Method for Component Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronics Letters Année : 2013
We explore the benefits of a redundant channels methodology for the component calibration. We propose a normal approximation of the yield in order to estimate the number of redundant components needed to provide a minimal area occupied by the components.
redund_caps_EL_1.pdf (156.31 Ko) Télécharger le fichier
hal-00932560 , version 1 (17-01-2014)
Farida Enikeeva, Dominique Morche, Alp Oguz. Yield Improvement by the Redundancy Method for Component Calibration. Electronics Letters, 2013, 49 (13), pp.824-826. ⟨10.1049/el.2012.4170⟩. ⟨hal-00932560⟩
142 Consultations
343 Téléchargements
