Assessing the Scalability of Garbage Collectors on Many Cores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Managed Runtime Environments (MRE) are increasingly used for application servers that use large multi-core hardware. We find that the garbage collector is critical for overall performance in this setting. We explore the costs and scalability of the garbage collectors on a contemporary 48-core multiprocessor machine. We present experimental evaluation of the parallel and concurrent garbage collectors present in OpenJDK, a widely-used Java virtual machine. We show that garbage collection represents a substantial amount of an application's execution time, and does not scale well as the number of cores increases. We attempt to identify some critical scalability bottlenecks for garbage collectors.
GC-scalability_PLOS-2011-10.pdf (210.14 Ko) Télécharger le fichier
hal-00932818 , version 1 (17-01-2014)
Lokesh Gidra, Gaël Thomas, Julien Sopena, Marc Shapiro. Assessing the Scalability of Garbage Collectors on Many Cores. PLOS '11 - 6th Workshop on Programming Languages and Operating Systems, Oct 2011, Cascais, Portugal. pp.7:1-7:5, ⟨10.1145/2039239.2039249⟩. ⟨hal-00932818⟩
228 Consultations
183 Téléchargements
