Approximated Lax Pairs for the Reduced Order Integration of Nonlinear Evolution Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2014
A reduced-order model algorithm, called ALP, is proposed to solve nonlinear evolution partial differential equations. It is based on approximations of generalized Lax pairs. Contrary to other reduced-order methods, like Proper Orthogonal Decomposition, the basis on which the solution is searched for evolves in time according to a dynamics specific to the problem. It is therefore well-suited to solving problems with progressive front or wave propagation. Another difference with other reduced-order methods is that it is not based on an off-line / on-line strategy. Numerical examples are shown for the linear advection, KdV and FKPP equations, in one and two dimensions.
RR-8454.pdf (988.92 Ko) Télécharger le fichier
hal-00933172 , version 1 (20-01-2014)
Jean-Frédéric Gerbeau, Damiano Lombardi. Approximated Lax Pairs for the Reduced Order Integration of Nonlinear Evolution Equations. Journal of Computational Physics, 2014, 265, pp.246-269. ⟨10.1016/j.jcp.2014.01.047⟩. ⟨hal-00933172⟩
236 Consultations
442 Téléchargements
