Cooperation and Competition Strategies in Multi-objective Shape Optimization - Application to Low-boom/Low-drag Supersonic Business Jet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cooperation and competition are natural laws that regulate the interactions between agents in numerous physical, or social phenomena. By analogy, we transpose these laws to devise e cient multi-objective algorithms applied to shape optimization problems involving two or more disciplines. Two e cient strategies are presented in this paper: a multiple gradient descent algorithm (MGDA) and a Nash game strategy based on an original split of territories between disciplines. MGDA is a multi-objective extension of the steepest descent method. The use of a gradient-based algorithm that exploits the cooperation principle aims at reducing the number of iterations required for classical multi-objective evolutionary algorithms to converge to a Pareto optimal design. On the other hand side, the Nash game strategy is well adapted to typical aeronautical optimization problems, when, after having optimized a preponderant or fragile discipline (e.g. aerodynamics), by the minimization of a primary objective-function, one then wishes to reduce a secondary objective-function, representative of another discipline, in a process that avoids degrading excessively the original optimum. Presently, the combination of the two approaches is exploited, in a method that explores the entire Pareto front. Both algorithms are rst analyzed on analytical test cases to demonstrate their main features and then applied to the optimum-shape design of a low-boom/low-drag supersonic business jet design problem. Indeed, sonic boom is one of the main limiting factors to the development of civil supersonic transportation. As the driving design for low-boom is not compliant with the low-drag one, our goal is to provide a trade-o between aerodynamics and acoustics. Thus Nash games are adopted to de ne a low-boom con guration close to aerodynamic optimality w.r.t. wave drag.
AIAA13_v5.pdf (2.29 Mo) Télécharger le fichier
hal-00935320 , version 1 (23-01-2014)
Andrea Minelli, Itham Salah El Din, Gérald Carrier, Adrien Zerbinati, Jean-Antoine Désidéri. Cooperation and Competition Strategies in Multi-objective Shape Optimization - Application to Low-boom/Low-drag Supersonic Business Jet. 43rd AIAA Fluid Dynamics Conference and Exhibit, The American Institute of Aeronautics and Astronautics (AIAA), Jun 2013, San Diego, California, United States. ⟨10.2514/6.2013-2648⟩. ⟨hal-00935320⟩
505 Consultations
361 Téléchargements
