A Regularity Result for Quasilinear Stochastic Partial Differential Equations of Parabolic Type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2015
We consider a quasilinear parabolic stochastic partial differential equation driven by a multiplicative noise and study regularity properties of its weak solution satisfying classical a priori estimates. In particular, we determine conditions on coefficients and initial data under which the weak solution is Hölder continuous in time and possesses spatial regularity that is only limited by the regularity of the given data. Our proof is based on an efficient method of increasing regularity: the solution is rewritten as the sum of two processes, one solves a linear parabolic SPDE with the same noise term as the original model problem whereas the other solves a linear parabolic PDE with random coefficients. This way, the required regularity can be achieved by repeatedly making use of known techniques for stochastic convolutions and deterministic PDEs.
Regularity9.pdf (371.53 Ko) Télécharger le fichier
hal-00935892 , version 1 (24-01-2014)
hal-00935892 , version 2 (26-05-2015)
Arnaud Debussche, Sylvain de Moor, Martina Hofmanova. A Regularity Result for Quasilinear Stochastic Partial Differential Equations of Parabolic Type. SIAM Journal on Mathematical Analysis, 2015, 47 (2), pp.1590-1614. ⟨10.1137/130950549⟩. ⟨hal-00935892v2⟩
259 Consultations
301 Téléchargements
