Content-Based Colour Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2013
This paper presents a novel content-based method for transferring the colour patterns between images. Unlike previous methods that rely on image colour statistics, our method puts an emphasis on high-level scene content analysis. We first automatically extract the foreground subject areas and background scene layout from the scene. The semantic correspondences of the regions between source and target images are established. In the second step, the source image is re-coloured in a novel optimization framework, which incorporates the extracted content information and the spatial distributions of the target colour styles. A new progressive transfer scheme is proposed to integrate the advantages of both global and local transfer algorithms, as well as avoid the over-segmentation artefact in the result. Experiments how that with a better understanding of the scene contents, our method well preserves the spatial layout, the colour distribution and the visual coherence in the transfer process. As an interesting extension, our method can also be used to re-colour video clips with spatially-varied colour effects.
Content-Based_Color_Transfer.pdf (1.32 Mo) Télécharger le fichier
hal-00937188 , version 1 (28-01-2014)
Fuzhang Wu, Weiming Dong, Yan Kong, Xing Mei, Jean-Claude Paul, et al.. Content-Based Colour Transfer. Computer Graphics Forum, 2013, 32 (1), pp.190-203. ⟨10.1111/cgf.12008⟩. ⟨hal-00937188⟩
281 Consultations
2178 Téléchargements
