The "exterior approach" to solve the inverse obstacle problem for the Stokes system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems and Imaging Année : 2014
We apply an "exterior approach" based on the coupling of a method of quasi-reversibility and of a level set method in order to recover a fixed obstacle immersed in a Stokes flow from boundary measurements. Concerning the method of quasi-reversibility, two new mixed formulations are introduced in order to solve the ill-posed Cauchy problems for the Stokes system by using some classical conforming infite elements. We provide some proofs for the convergence of the quasi-reversibility methods on the one hand and of the level set method on the other hand. Some numerical experiments in 2D show the effciency of the two mixed formulations and of the exterior approach based on one of them.
hal-00937768 , version 1 (28-01-2014)
Laurent Bourgeois, Jérémi Dardé. The "exterior approach" to solve the inverse obstacle problem for the Stokes system. Inverse Problems and Imaging , 2014, pp.Pages: 23 - 51. ⟨10.3934/ipi.2014.8.23⟩. ⟨hal-00937768⟩
239 Consultations
0 Téléchargements
