Effective Transmission Conditions for Thin-Layer Transmission Problems in Elastodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This research is motivated by the numerical modelling of ultrasonic non-destructive testing experiments. Some tested media feature thin layers which are difficult to handle in numerical computations due to the very small element size required for meshing them. To overcome these difficulties, one idea consists in using effective transmission conditions (ETCs) across the two interfaces bounding the layer. This work aims at establishing such ETCs by means of a formal asymptotic analysis with respect to the (small) layer thickness.
papier_158.pdf (133.01 Ko) Télécharger le fichier
hal-00937962 , version 1 (29-01-2014)
  • HAL Id : hal-00937962 , version 1
Marc Bonnet, Aliénor Burel, Patrick Joly. Effective Transmission Conditions for Thin-Layer Transmission Problems in Elastodynamics. WAVES 2013 - 11th International Conference on Mathematical an Numerical Aspect of Waves, Jun 2013, Gammarth, Tunisia. ⟨hal-00937962⟩
350 Consultations
72 Téléchargements
