Deterministic Policy Gradient Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we consider deterministic policy gradient algorithms for reinforcement learning with continuous actions. The deterministic pol- icy gradient has a particularly appealing form: it is the expected gradient of the action-value func- tion. This simple form means that the deter- ministic policy gradient can be estimated much more efficiently than the usual stochastic pol- icy gradient. To ensure adequate exploration, we introduce an off-policy actor-critic algorithm that learns a deterministic target policy from an exploratory behaviour policy. We demonstrate that deterministic policy gradient algorithms can significantly outperform their stochastic counter- parts in high-dimensional action spaces.
dpg-icml2014.pdf (335.61 Ko) Télécharger le fichier
hal-00938992 , version 1 (29-01-2014)
  • HAL Id : hal-00938992 , version 1
David Silver, Guy Lever, Nicolas Heess, Thomas Degris, Daan Wierstra, et al.. Deterministic Policy Gradient Algorithms. ICML, Jun 2014, Beijing, China. ⟨hal-00938992⟩
6510 Consultations
11733 Téléchargements
