Method for Identifyng and Detecting a Radio Signal For a Cognitive Communication System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2013
A method of identifying an RF signal for a cognitive radio system. The signal is identified with a digital watermarking performed downstream from the digital modulation of the symbols to be transmitted. A method of detecting an RF signal watermarked is also disclosed. The identification method includes demodulating the received RF signal as a baseband, converting it digitally, and correlating the digital signal obtained with a predetermined digital signature. The correlation values are averaged using a recursive filter and the maximum value of the average values output from the filter is compared to a threshold to decide whether the RF signal is present.
Fichier non déposé
hal-00939225 , version 1 (30-01-2014)
  • HAL Id : hal-00939225 , version 1
Matthieu Gautier, Dominique Noguet. Method for Identifyng and Detecting a Radio Signal For a Cognitive Communication System. United States, Patent n° : US Patent, 20130251014. 2013. ⟨hal-00939225⟩
222 Consultations
0 Téléchargements
