Analysis of Two-Sensors Forward BSS Structure With Post-Filters in The Presence of Coherent and Incoherent Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Speech Communication Année : 2013
We consider the speech enhancement problem in a moving car through a blind source separation BSS scheme involving two sensors. To correct the distortion brought by this structure we have proposed in previous work (Djendi et al., 2007) two frequency-domain methods to compute the post-filters placed at the output of the forward BSS structure (FBSS). In this work, we consider the case where the noises at the sensor inputs contain coherent and non-coherent components. We provide an analysis of the performance (output SNR and the distortion criterion) of the FBSS structure with post-filters as a function of two new parameters: the coherent to diffuse ratio (CDR) andhe speech to coherent ratio (SCR). Simulation results show perfect agreement between theoretical and experimental results.
Fichier non déposé
hal-00939967 , version 1 (31-01-2014)
  • HAL Id : hal-00939967 , version 1
Mohamed Djendi, Pascal Scalart, André Gilloire. Analysis of Two-Sensors Forward BSS Structure With Post-Filters in The Presence of Coherent and Incoherent Noise. Speech Communication, 2013, 55, pp.975-987. ⟨hal-00939967⟩
236 Consultations
0 Téléchargements
