On the design of coded MIMO systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we investigate two approaches which deal with the construction of space-time block (STB) codes for a system possessing a forward error correcting (FEC) code at the transmitter side. The first approach designs the STB codes to be optimal for a system equipped by a turbo MMSE equalizer at the receiver side, with a minimum peak to average power ratio (PAPR) constraint. The second one proposes to design the STB codes according to a non-asymptotic design criterion based on the bitwise mutual information (BMI) maximization at a specific target SNR. Performance assessments of designed codes are validated by Monte Carlo simulations.
Electronique
Fichier non déposé
hal-00940407 , version 1 (31-01-2014)
  • HAL Id : hal-00940407 , version 1
Mohamad Sayed Hassan, Ammar El Falou, Charlotte Langlais. On the design of coded MIMO systems. ICCIT : the 3rd International Conference on Communications and Information Technology, Jun 2013, Beyrouth, Lebanon. pp.335-339. ⟨hal-00940407⟩
357 Consultations
0 Téléchargements
