Faster Algorithms for Multivariate Interpolation with Multiplicities and Simultaneous Polynomial Approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2015
The interpolation step in the Guruswami-Sudan algorithm is a bivariate interpolation problem with multiplicities commonly solved in the literature using either structured linear algebra or basis reduction of polynomial lattices. This problem has been extended to three or more variables; for this generalization, all fast algorithms proposed so far rely on the lattice approach. In this paper, we reduce this multivariate interpolation problem to a problem of simultaneous polynomial approximations, which we solve using fast structured linear algebra. This improves the best known complexity bounds for the interpolation step of the list-decoding of Reed-Solomon codes, Parvaresh-Vardy codes, and folded Reed-Solomon codes. In particular, for Reed-Solomon list-decoding with re-encoding, our approach has complexity $\mathcal{O}\tilde{~}(\ell^{\omega-1}m^2(n-k))$, where $\ell,m,n,k$ are the list size, the multiplicity, the number of sample points and the dimension of the code, and $\omega$ is the exponent of linear algebra; this accelerates the previously fastest known algorithm by a factor of $\ell / m$.
MultivariateInterpolation-PolyApprox_v2.pdf (559.09 Ko) Télécharger le fichier
hal-00941435 , version 1 (03-02-2014)
hal-00941435 , version 2 (13-02-2015)
Muhammad Foizul Islam Chowdhury, Claude-Pierre Jeannerod, Vincent Neiger, Eric Schost, Gilles Villard. Faster Algorithms for Multivariate Interpolation with Multiplicities and Simultaneous Polynomial Approximations. IEEE Transactions on Information Theory, 2015, pp.2370-2387. ⟨10.1109/TIT.2015.2416068⟩. ⟨hal-00941435v2⟩
583 Consultations
464 Téléchargements
