Using a SEEK filter as data assimilation kernel in NEMOVAR inner loops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Contrat/Projet) Année : 2010
Data assimilation (DA) is divided in two main branches: (i) variational assimilation and (ii) stochastic assimilation. Unlike variational assimilation, stochastic assimilation does not rely on a functional minimization with iterative process and gradient estimations. The stochastic branch includes Kalman Filter-type approaches and low rank approximations such as SEEK Filter. NEMOVAR is designed for variational applications, however its two stages inner-outer loops allow for different assimilation kernel in the inner loop. The present report study the use of a SEEK filter within NEMOVAR.
D3.3.pdf (5.08 Mo) Télécharger le fichier
hal-00941701 , version 1 (04-02-2014)
  • HAL Id : hal-00941701 , version 1
Bénédicte Lemieux, Jean-Michel Brankart, Arthur Vidard. Using a SEEK filter as data assimilation kernel in NEMOVAR inner loops. [Contract] D3.3, 2010, pp.44. ⟨hal-00941701⟩
208 Consultations
251 Téléchargements
