Control with constraints for linear stationary systems: An interpolation approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automation and Remote Control / Avtomatika i Telemekhanika Année : 2014
We propose a new approach to controlling a discrete linear stationary system with a polyhedral constraint on the state and input. The basic idea is to use interpolation. The control law has both explicit and implicit forms. In the implicit form, at any moment of time, at most two linear programming problems are solved online. In the explicit form, the control law contains piecewise affine and continuous functions of state. This method can be viewed as an alternative to predictive control. We show proofs of recursive realizability and asymptotic stability.
Fichier non déposé
hal-00944453 , version 1 (10-02-2014)
H.-N. Nguyen, P.O. Gutman, Sorin Olaru, Morten Hovd. Control with constraints for linear stationary systems: An interpolation approach. Automation and Remote Control / Avtomatika i Telemekhanika, 2014, 75 (1), pp.57-74. ⟨10.1134/S0005117914010044⟩. ⟨hal-00944453⟩
119 Consultations
0 Téléchargements
