Sliding window adaptive SVD algorithms
The singular value decomposition (SVD) is an important tool for subspace estimation. In adaptive signal processing, we are especially interested in tracking the SVD of a recursively updated data matrix. This paper introduces a new tracking technique, designed for rectangular sliding window data matrices. This approach, derived from the classical bi-orthogonal iteration SVD algorithm, shows excellent performance in the context of frequency estimation. It proves to be very robust to abrupt signal changes, due to the use of a sliding window. Finally, an ultra-fast tracking algorithm with comparable performance is proposed.
