Adaptive filtering for music/voice separation exploiting the repeating musical structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The separation of the lead vocals from the background accompani- ment in audio recordings is a challenging task. Recently, an efficient method called REPET (REpeating Pattern Extraction Technique) has been proposed to extract the repeating background from the non- repeating foreground. While effective on individual sections of a song, REPET does not allow for variations in the background (e.g. verse vs. chorus), and is thus limited to short excerpts only. We overcome this limitation and generalize REPET to permit the processing of complete musical tracks. The proposed algorithm tracks the period of the repeating structure and computes local estimates of the background pattern. Separation is performed by soft time-frequency masking, based on the deviation between the current observation and the estimated background pattern. Evaluation on a dataset of 14 complete tracks shows that this method can perform at least as well as a recent competitive music/voice separation method, while being computationally efficient.
adaptive_repet.pdf (222.75 Ko) Télécharger le fichier
hal-00945300 , version 1 (13-03-2014)
Antoine Liutkus, Zafar Rafii, Roland Badeau, Bryan Pardo, Gael Richard. Adaptive filtering for music/voice separation exploiting the repeating musical structure. 37th International Conference on Acoustics, Speech, and Signal Processing ICASSP'12, 2012, Kyoto, Japan. pp.53--56, ⟨10.1109/ICASSP.2012.6287815⟩. ⟨hal-00945300⟩
209 Consultations
1339 Téléchargements
