Abstract Interpretation of Temporal Concurrent Constraint Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory and Practice of Logic Programming Année : 2015
Timed Concurrent Constraint Programming (tcc) is a declarative model for concurrency offering a logic for specifying reactive systems, i.e. systems that continuously interact with the environment. The universal tcc formalism (utcc) is an extension of tcc with the abil- ity to express mobility. Here mobility is understood as communication of private names as typically done for mobile systems and security protocols. In this paper we consider the denotational semantics for tcc, and we extend it to a "collecting" semantics for utcc based on closure operators over sequences of constraints. Relying on this semantics, we formalize a general framework for data flow analyses of tcc and utcc programs by abstract inter- pretation techniques. The concrete and abstract semantics we propose are compositional, thus allowing us to reduce the complexity of data flow analyses. We show that our method is sound and parametric with respect to the abstract domain. Thus, different analyses can be performed by instantiating the framework. We illustrate how it is possible to reuse abstract domains previously defined for logic programming to perform, for instance, a groundness analysis for tcc programs. We show the applicability of this analysis in the context of reactive systems. Furthermore, we make also use of the abstract semantics to exhibit a secrecy flaw in a security protocol. We also show how it is possible to make an analysis which may show that tcc programs are suspension free. This can be useful for several purposes, such as for optimizing compilation or for debugging.
utcc-abs-tplp-CR.pdf (517.62 Ko) Télécharger le fichier
hal-00945462 , version 1 (12-02-2014)
  • HAL Id : hal-00945462 , version 1
Moreno Falaschi, Carlos Olarte, Catuscia Palamidessi. Abstract Interpretation of Temporal Concurrent Constraint Programs. Theory and Practice of Logic Programming, 2015, 15 (3), pp.312-357. ⟨hal-00945462⟩
447 Consultations
166 Téléchargements
