Numerical solution of the Monge-Kantorovich problem by Picard iterations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We present an iterative method to numerically solve the L² Monge-Kantorovich problem. The method is based on a Picard fixed point iteration of the linearized problem. Examples relative to the transport of two-dimensional densities show that the present method can significantly reduce the computational time over existing methods, especially when the Wasserstein distance between the densities is small.
RR-8477.pdf (1018.73 Ko) Télécharger le fichier
hal-00946252 , version 1 (14-02-2014)
  • HAL Id : hal-00946252 , version 1
Afaf Bouharguane, Angelo Iollo, Lisl Weynans. Numerical solution of the Monge-Kantorovich problem by Picard iterations. [Research Report] RR-8477, INRIA. 2014. ⟨hal-00946252⟩
741 Consultations
989 Téléchargements
