Computing least squares condition numbers on hybrid multicore/GPU systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This paper presents an efficient computation for least squares conditioning or estimates of it. We propose performance results using new routines on top of the multicore-GPU library MAGMA. This set of routines is based on an efficient computation of the variance-covariance matrix for which, to our knowledge, there is no implementation in current public domain libraries LAPACK and ScaLAPACK.
RR-8479.pdf (426.05 Ko) Télécharger le fichier
hal-00947204 , version 1 (14-02-2014)
hal-00947204 , version 2 (28-02-2014)
  • HAL Id : hal-00947204 , version 2
Marc Baboulin, Jack Dongarra, Rémi Lacroix. Computing least squares condition numbers on hybrid multicore/GPU systems. [Research Report] RR-8479, INRIA. 2014. ⟨hal-00947204v2⟩
464 Consultations
371 Téléchargements
