Clock Jitter Effect on Switched-Capacitor Filter Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fluctuation and Noise Letters Année : 2006
This paper proposes the study of clock jitter effect on high-Q switched-capacitor filter behavior. A command circuit made up by a ring voltage controlled oscillator (VCO) with XOR gates is used to generate the command signals. According to the correlation of these signals the jitter effect on the signal constellation has been studied. A good agreement between measured and simulation results has been achieved which validate our design methodology.
PNL.pdf (742.88 Ko) Télécharger le fichier
hal-00947411 , version 1 (16-02-2014)
Ahmed El Oualkadi, Jean-Marie Paillot, Denis Flandre. Clock Jitter Effect on Switched-Capacitor Filter Design. Fluctuation and Noise Letters, 2006, 6 (1), ⟨10.1142/S0219477506003112⟩. ⟨hal-00947411⟩
Collections
UNIV-POITIERS LIAS
87 Consultations
205 Téléchargements
