Some results on the Weiss-Weinstein bound for conditional and unconditional signal models in array processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2014
Dinh Thang Vu
  • Fonction : Auteur
  • PersonId : 865876
Alexandre Renaux
Remy Boyer
Sylvie Marcos
In this paper, the Weiss-Weinstein bound is analyzed in the context of sources localization with a planar array of sensors. Both conditional and unconditional source signal models are studied. First, some results are given in the multiple sources context without specifying the structure of the steering matrix and of the noise covariance matrix. Moreover, the case of an uniform or Gaussian prior are analyzed. Second, these results are applied to the particular case of a single source for two kinds of array geometries: a non-uniform linear array (elevation only) and an arbitrary planar (azimuth and elevation) array.
_J20_.pdf (349.37 Ko) Télécharger le fichier
hal-00947784 , version 1 (17-02-2014)
Dinh Thang Vu, Alexandre Renaux, Remy Boyer, Sylvie Marcos. Some results on the Weiss-Weinstein bound for conditional and unconditional signal models in array processing. Signal Processing, 2014, 95 (2), pp.126-148. ⟨10.1016/j.sigpro.2013.08.020⟩. ⟨hal-00947784⟩
189 Consultations
128 Téléchargements
