s'authentifier
version française rss feed
hal-00950862, version 2
TBX goes TEI -- Implementing a TBX basic extension for the Text Encoding Initiative guidelines
Laurent Romary () 123
Terminology and Knowledge Engineering 2014 (2014)
Résumé : This paper presents an attempt to customise the TEI (Text Encoding Initiative) guidelines in order to offer the possibility to incorporate TBX (TermBase eXchange) based terminological entries within any kind of TEI documents. After presenting the general historical, conceptual and technical contexts, we describe the various design choices we had to take while creating this customisation, which in turn have led to make various changes in the actual TBX serialisation. Keeping in mind the objective to provide the TEI guidelines with, again, an onomasiological model, we try to identify the best comprise in maintaining both the isomorphism with the existing TBX Basic standard and the characteristics of the TEI framework.
  • hal-00950862, version 2
  • oai:hal.inria.fr:hal-00950862
  • Contributeur :
  • Soumis le : Samedi 1 Mars 2014, 06:53:47
  • Dernière modification le : Vendredi 19 Septembre 2014, 16:55:18
tous les articles de la base du CCSd...
