Manipulating Models Using Internal Domain-Specific Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In Model-Driven Engineering, a number of external Domain-Specific Languages (DSL) for model manipulation have been proposed. However, they require users to learn new languages that, together with their execution performance, usability and tool support limitations, can significantly contribute to accidental complexities. In this paper, we present an alternative approach based on internal DSLs in Scala for model consistency checking and model transformations for the Eclipse Modeling Framework.
pl14-paper.pdf (105.18 Ko) Télécharger le fichier
hal-00951803 , version 1 (26-02-2014)
  • HAL Id : hal-00951803 , version 1
Filip Krikava, Philippe Collet, Robert France. Manipulating Models Using Internal Domain-Specific Languages. Symposium On Applied Computing, Mar 2014, Gyeongju, South Korea. ⟨hal-00951803⟩
293 Consultations
409 Téléchargements
