Descriptor Optimization for Multimedia Indexing and Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose and evaluate a method for optimizing descriptors used for content-based multimedia indexing and retrieval. A large variety of descriptors are commonly used for this purpose. However, the most efficient ones often have characteristics preventing them to be easily used in large scale systems. They may have very high dimensionality (up to tens of thousands dimensions) and/or be suited for a distance costly to compute (e.g. fflchi-square). The proposed method combines a PCA-based dimensionality reduction with pre- and post-PCA non-linear transformations. The resulting transformation is globally optimized. The produced descriptors have a much lower dimensionality while performing at least as well, and often significantly better, with the Euclidean distance than the original high dimensionality descriptors with their optimal distance. The method has been validated and evaluated for a variety of descriptors using TRECVid 2010 semantic indexing task data. It has then be applied at large scale for the TRECVid 2012 semantic indexing task on tens of descriptors of various types and with initial dimensionalities from 15 up to 32,768. The same transformation can be used also for multimedia retrieval in the context of query by example and/or relevance feedback.
cbmi13.pdf (110.66 Ko) Télécharger le fichier
hal-00953090 , version 1 (28-02-2014)
  • HAL Id : hal-00953090 , version 1
Bahjat Safadi, Georges Quénot. Descriptor Optimization for Multimedia Indexing and Retrieval. CBMI 2013, 11th International Workshop on Content-Based Multimedia Indexing, 2013, Veszprem, Hungary. ⟨hal-00953090⟩
218 Consultations
333 Téléchargements
